Installation instructions for Windows via WSL
WSL Configuration
Clock on Windows host
If Windows host time is not correct, it should be corrected in Settings/'Time and language' (choose 'Set time automatically', 'Set time zone automatically' and 'Synchronize clock' with 'Synchronize now')
Restart the machine
Installing WSL and Ubuntu
WSL (Windows Subsystem for Linux) lets developers run a GNU/Linux environment directly on Windows, without traditional virtual machine.
Run Windows Powershell as an administrator (right click)
Type the following in the command prompt of Windows Powershell
- If Windows 11
wsl --install Ubuntu-22.04
- If Windows 10
wsl --install -d Ubuntu-22.04
Ubuntu credentials
If WSL and Ubuntu installations have been successful, an Ubuntu window opens. Then the user is proposed to create an identifier with an associated password (to be memorized).
Updating WSL and using Ubuntu in WSL2 version
Close Ubuntu window and return to Windows Powershell window.
Type the following in the command prompt (it may take a few minutes)
wsl --update
wsl --set-version Ubuntu-22.04 2
Ubuntu Setup
Open Ubuntu window again by clicking on the corresponding icon in Windows menu and type the following
sudo apt update
then answer 'Y'
sudo apt upgrade
then answer 'Y'
sudo apt install x11-apps libarchive13
then answer 'Y'
Requirements
Conda is a package management system and environment management system.
The easiest and fastest way to get the package up and running is to install miniconda and to use mamba, which is much faster than conda.
Type the following two lines in Ubuntu to install conda from miniconda
wget https://repo.anaconda.com/miniconda/Miniconda3-latest-Linux-x86_64.sh
bash Miniconda3-latest-Linux-x86_64.sh
then 'Enter'
space (several times),
'yes'
'ENTER' (default)
Answer 'yes' to (conda init)
Close and reopen Ubuntu window.
To install mamba, run what follows
conda install -c conda-forge mamba
(answer 'yes')
Setting up the conda environment
We recommend installing nm-bridge into a separate environment called neuromod, see conda's documentation for more details. To do so, use:
mamba create -n neuromod
conda activate neuromod
In the neuromod environment, we will need several dependencies, used in the demo script, which we install as follows
mamba install -c conda-forge r-igraph jupyter
(answer 'yes')
Installing nm-bridge
We install nm-bridge in the neuromod environment as follows:
mamba install -c neuromod -c conda-forge nm-bridge python=3.10
(answer 'yes')
Updating nm-bridge
In case of update of nm-bridge, run inside the neuromod environment, in Ubuntu window
mamba update -c neuromod -c conda-forge nm-bridge
